AQ271C only running at 3400 WOT
benet
I have A 1989 aq271c WITH THE 290 DP when running at wide open throttle is is only acheving 3400 RPM's
Have put in a new fuel pump, changed the fuel filter, had a mechanic set the timing . Could the carb be causing this?
Don S
Re: AQ271C only running at 3400 WOT
This is a list of possible causes of low WOT (Wide Open Throttle) rpm.
In no particular order
Verify, don't just "ASSUME" each is correct.
Engine Won't Reach Operating RPM. Check
1. Fuel condition. Type and Octane possibly old fuel
2. Propeller pitch or diameter, damaged blades
3. Restricted fuel pickup tube or anti siphon valve Fuel System Test
4. Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
5. Marine growth on hull and outdrive
6. Wrong gear ratio in outdrive
7. Restricted carburetor air intake (clogged flame arrestor)
8. Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
9. Poor cylinder compression Compression Test
10. Carburetor defective, or wrong type.
11. Fuel pump pressure and vacuum
12. Boat overloaded, improperly loaded, or improperly trimmed.
13. Engine Overheating
14. Engine timing and ignition system operation
15. Remote control cables and linkage for proper travel to open throttle plates fully.
benet
Thnnks for the reply I will have the mechanic recheck the timing and check the Carb
