aq271c starter...
discotu
Hi all, im re-installing my starter but now i can't get it to turn over. i can hear the relay clicking, but the starter isn't getting 12V to the "S" terminal. the smaller gauge (yellow/red) "R" terminal is getting power though.Any ideas where to start probing?
thanks!
Brian
discotu
Re: aq271c starter...
btw i did run through the " starter trouble shooting" tips and im able to "jump" the starter straight from the battery so i know its good. however, im not able to jump the starter when i short the A and B terminals on the relay....
discotu
im starting to think it's a bad starter solenoid...any additional help would be appreciated!
Don S
The yellow/red wire goes on the "S" (start) terminal. not the R terminal.
discotu
oops, typo on my part...after several hours of checking and rechecking, i finally resorted to "tapping" the solenoid out of frustration...voila! sheesh i should've started with that! Engine started right up and purrs like a kitten. thanks!
Don S
Just like a computer, garbage in, garbage out.
Tapping on a solenoid isn't a fix, it just shows you where the problem is.
discotu
agreed, its on my list of things to replace. just glad that the engine seems fine!
