Aq280 inter housing oil tube replacment?
wrbowcal
Hello,Need to remove oil tube 814386 off my old housing and install in the one I purchased on ebay.How is the best way to remove it without damage?
Note:Ebay purchase paid by CC on phone, sent me crappy part got fleeced not the one listed now Im stuck with it and I am to scared to send it back.Lesson learned there.
Don S
Re: Aq280 inter housing oil tube replacment?
That isn't the part number for the oil tube, which one are you trying to replace?
attachment.php
wrbowcal
Good eye,Copied the wrong part # The oil tube Don # 897644
Don S
Can't help you with that one, never had to replace one or seen one go bad. Looked in the manual and nothing about it either.
wrbowcal
I will heat the case around it and try to knock it out.The yo yo that sold it to me said epoxy my old one in.I know there is little on info on that part.
I also have to resurface the face on the lower where the water pipe on the fork contacts the lower, its pitted and corroded bad Im thinking liquid steel,JB weld.Then probably local machine shop to mill it flat.
