Aqua Meter Tachometer inop
Lakeshadow
Hi, I have an old Aqua Meter tach I bought last year new yet without the box or paperwork. It is model #250. It is adjustable between 1 and 6 pulses.
It has a grey pulse wire and black ground wire. The pulse wire is connected to the cut out switch mounting screw. Black is grounded.
The tach does not work.
Double checking to see if it is the tach that is faulty.
Thanks a bunch....
Lakeshadow
Re: Aqua Meter Tachometer inop
Sorry about that, new this year, running a '65 Evinrude Ski-Twin 33 pony.
Lakeshadow
Special thanks to tallcanadian for supplying paperwork on the tachometer. I do have it wired correctly.
Uploading photographs is failing. I will try again later.
Just tried again, think the files are too big. I can send them to an e-mail address if anyone is interested. P.m. me with e-mail and I'll send the photographs.
Thanks...
delreybob
I have the same tach as shown in your post. The two wires (black and gray) were disconnected when I purchased the 1969 boat. Can you confirm where these wires are to be connected.
Thanks...
Lakeshadow
I can send you the pics of the instruction sheets an email address.
Edit: Send a pm instead........... WIMUSKY
delreybob
Thank you for your response.
If will will make any difference, my boat is a 69 Vance (Donzi knockoff) runabout. It has a 289 Ford motor and a Volvo Penta outdrive.
Edit: Do not post your personal contact information such as email address, home address, home phone numbers, etc. on the forums.
Lakeshadow
Aqua Meter instruction sheets.
Lakeshadow
I did have the tachometer wired correctly the whole time. It has taken this long to find another NOS Aqua-Meter tach, and a practice one to make sure. With no spark plugs in the engine the starter spins the outboard around at 700 r.p.m.'s..... Decent...
