Are all 2 strokes like that?
ozenine
Hi all,
I have 2010 50hp Merc 2 stroke. it runs fine under load, but when it is idling it often dies and takes a long time to start again. It happpens not only when it is cold, but after some extensive use. So I am just wondeing if all 2 strokes are like taht or you guys something is wrong with it.
Motor is still under full warranty, howeve I would like to save myself a trip tot he dealer.
Thanks!
canoemang
Re: Are all 2 strokes like that?
Nope.. i have a 1986 115 Merc, it will idle for days cold or warm and if i kill it, it fires rite back up.. everytime!
marty53
Hi all,
Thanks!
All 2 strokes are definitely not like that. My 1991 will idle all day, and always starts right up when its already warm. Sounds like you should take it back to the dealer
ozenine
Thanks guys. I suspected this. I am more worried about my wife driving the boat, if I can play with gas to keep it running, she cannot......
Will take it to the dealer tonight.
hotrod53
My 2 stroke starts right up hot or cold. A quick blip of the key when its warm and its fired up again. I can however tell you that each has its own personallity and you need to learn it. I start mine cold with 40% warm up lever, when restarting, no warm up lever, after fishing for a while and it gets good and cold, I need the warmup lever again, too much warm up lever and it doesn't want to start.
xjma
sounds like the plugs may be fouled. Is it injection or are you premixing?? If premixing, measure the ratio correctly!!
Try pulling the plugs, and if the electrode has all black gunk on it, clean as much of it off as you can. if it starts better, that's your issue.
