Are lifting eyes used to lift entire outboards?
gwoloshyn
I'm planning on hoisting my 110hp outboard up off a stand to install on my boat in a few weeks and looking into options for doing this. I've seen the lifting eyes that you attach to the flywheel, are these used to pull the powerhead off outboards or used to lift the whole outboard? Or both? This is my favorite option, as I can make one myself using steel and grade 8 bolts.
I could also use straps around the motor but this doesn't seem like the best idea.
82rude
Re: Are lifting eyes used to lift entire outboards?
used for lifting the whole motor.
roscoe
gwoloshyn
Actually I just checked my motor and there is a lift ring bolted to the powerhead. Thanks
82rude
there! problem solved.
V153
I personally would not lift by the flywheel with a hame made apparatus
Really!? I've lifted several motors with this one & never had a problem. Doubles as a flywheel puller too btw ...
coolbri70
I take the handle off the cowling, then I can hook to the lifting eye with the cowl on, then stuff a rag around the hole to keep out the weather, I left it hang from the hoist while I redid my transom
roscoe
For safety sake, too many unknown variables.
(materials being used, condition of flywheel, skill of person making the part)
Just don't want someone to get hurt.
I've seen motors fall.
I also don't like putting things thru the flywheel where the ignition components could be damaged.
If you have the skills to make one, and the knowledge to do it well, then go for it.
