............The thing that makes the distributor marine is it's being "Igniton Protected" which means the sparks going on inside the distributor will not ignite gas fumes that could be in the bilge should you have a fuel leak.
Hey Don....How does that work? Lots of arc and spark under the cap. What makes marine safe there?
Ayuh,.... Either screened, or elbowed vents,...
A spark can't pass a screen, 'n can't turn corners...
There is no such thing as marine grade points, you just have to make sure that the points you get fit your particular distributor. Marine distributors do not have vacuum advances but the points will have commonality with other auto distributors. Best for you however would be to convert your points to a Pertronix II ignitor.
It doesn't.Would that effect the electric shift, have a 72 sterndrive omc. I wanted to change to Pertronix but read , probably on this forum,that it effects the electric shift. yes or no ??
Thanks Rich
OK Guys have been looking all over on this. Is there any difference if I use auto points and condensor? I have 1987, 3.0 OMC. Changing out points and tuning up this winter. Running good other wise. Chime in your voice matters.
Yes there is a problem with the ESA when you switch to Pertronix. You either do the diode fix that Pertronix explains on their website or you buy the CDI ESA to replace the OMC one.
