Are Mercury starter 10 tooth drive gears all the same?
MiBad
I just had the starter rebuilt for my '89 Mercury 115 HP outboard. I intentionally had the starter rebuilt as opposed to buying a replacement because I wanted to make sure I had the same 10 tooth drive gear and the replacements seem to have gone to an 8 tooth drive. Even the Mercury replacement drive gear for my starter is an 8 tooth drive. I installed the rebuilt starter and now when I try to start the motor the drive gear rises as it should and spins as fast as I would think it should. The problem is that it does not mesh with the flywheel. I've had the starter on and off a few times before and after the rebuild and it looks like it only goes in one way. One of the mechanics at the local marina suggested that I check the voltage drop at the starter which I will be doing as soon as I am sure (again) that my battery is fully charged. I don't think that a poor connection is the problem because I would think that if the starter spins fast enough for the drive gear to move up to the flywheel, it would engage the flywheel and then crank slowly or stall if there wasn't enough current. But this does not happen. The drive gear spins and seems to bump into the flywheel and continues to spin rubbing the bottom of the flywheel.The only thing I can think of causing this would be the wrong size 10 tooth drive gear, but I don't know if Mercury makes more than one size. The local marina was helpful in that they looked up and pulled the drive gear for my motor from their stock to compare with what I have now, but they only stock the 8 tooth gear which seems to be what Mercury has standardized on for my starter. I am trying to give the shop that rebuilt my starter the benefit of the doubt when they say that they rebuilt my starter, but I don't know if they swapped mine with another that looked the same but has a slightly different drive gear. After my battery is topped off I'll go back to check voltage drops, but I don't want to waste any more time if I have the wrong starter or drive gear - so if Mercury only makes one size 10 tooth drive gear I'll continue troubleshooting, but I can't help but to think that I have a bad or the incorrect rebuilt starter. With the weekend getting closer I want to be able to order any parts I might need.
Thanks in advance for any input...
