Re: Are there any "Do it yourselfe" Repair guide for propellers & how to balance them
Not sure how common propeller shops are in your location, however down here in Florida, we have a phenomenal propeller shop that charges a reasonable price. and they guarantee their work.
that being said, here is my "Do it yourself" guide
Remove propeller
drop off at shop
go to lunch with wife
have a few beers
pick up propeller
install.
Unless your "Swedish Concrete" Anvil is hardened tool steel like the propeller shops use, you will get movement with every hammer blow. there is no way you can make each blade within 1/100 mm of each other, even if you were wire EDM machining the blades.
I will give you that you may be able get them within 1/2mm of each other, however with considerable time and labor.
Now, I have straightened nicks and rock dings a bit using my anvil and shaping hammer, even with a hand dolly and hammers However I wouldnt attempt a serious repair.
