bobgritz
- Sep 22, 2009
- 185
Here is a pic of the reed valves on my 1983 15hp Johnson. The first picture shows the valves when held at an angle and you can see 'light' coming through a gap between the valve and the plate. Is that normal and acceptable or should the valves lay tight against the plate. I assume it's a practical idea to replace both the leaf-valves and the leaf-stops?
Also, could someone identify that narrow channel (best view in 2nd picture) that extends from one side of the valve plate to the other side. I'm just curious as to its purpose and to its importance with respect to the engine's operation. Should I blow out the ports in the powerhead where this channel enters and exits (and what is a safe air pressure).
