Beefer
- Aug 4, 2008
- 1,737
Ok, I think I'm going to go nuts trying to install a tachometer. The boat is a 1994 Bayliner Capri 16', with a 1994 70HP Force. Tach is a Teleflex. My problem is (at this point) figuring out which wire is the tach sending wire. Under the dashboard/console, I have 3 unused wires coming from the engine; 1) tan 2) Black w/white stripe 3) Grey w/black stripe. On the iginition, there is 1) yellow w/red stripe 2) purple 3) yellow w/black stripe (and a couple of others that I forgot the colors of).
I was told that if you hook up a test light when the engine is running, the one for the tach will have a pulse/strobe effect. The 3 unused wires did not light the test light at all, and I did not want to disconnect the ones from the ignition to test until I knew what each was for.
Does anyone know which wire is the tachometer sending wire? In the engine, I honestly don't know what I'm looking for, and most of the wires are in shrouds or what the connect to is not visible.
Anyone have any ideas?
