ASAP 150 Force, please respond ASAP
tonycrespo
Can someone tell what to tighten my exhaust manifold bolts to. I have been checking around and I saw one person say 70 inch lbs and then I saw another thinking 200 inch lbs? What are your toughts
roscoe
Re: ASAP 150 Force, please respond ASAP
my book says 70 in #
tonycrespo
thanks Roscoe....70 it is....Water leak is non existent now but I still have a problem with the motor missing. Compression good, new plugs, replaced on bad Cd module. Sometimes it runs smooth and then all of a sudden it spits and carries on. I'm afraid it break somthing when it acts like that
john from md
Have you pulled each of the plug wires off to determine which cylinder is suspect? If not, you need to do so to narrow the problem down.
John
