Asking price?
thedinz
I hope this is the right forum as im asking a engine question technically.
Hey guys, if you read my other thread i decided NOT to rebuild my searay. Instead im going to buy something new, already have my eye on something.
Anywhoo, im wondering what i can get for selling a few items. I spent a good amount of money last year on the engine, outdrive, bellow etc etc. Then also i figure i could sell the trailer, dual axel, new bearings & lights, good tires. Ready to haul. (see pictures attached)
Now on to the details.
The way the PO stored the boat the outdrive was seized up. So it was rebuilt, the bellows also was corroded and in bad shape so we rebuilt most of that. The engine is a mercuriser 4 cylinder 165 runs great strong, but i had to fix some things. See the arrow in the picture, these engines have that horrible alternator inside the engine, they are a pain in the ass to fix and costly. Of coarse it went on me the second day on the boat. Instead of repairing it we by passed it with a normal alternator setup (see #1 in the picture) this is a much BETTER setup. Now #2 is the heat exchanger this wnet bad as well and was replaced. Another expensive part but now its all fixed. I have receipts for all the work. A list of all new parts......
  • Replace upper u-joint shaft crossbearings and reseal upper as unit
    had trace amounts of waer in gear oil, Replace all seals in lower unit
    also and replace waterpump assy and reassy fill with gear oil
  • Exhaust pipe seal/gasket
  • Transom Seal Kit (Bellows,Hoses, etc.)
  • UNIVERSAL JOINT
  • CARRIER ASSEMBLY
  • S EAL KIT Upper
  • S EAL KIT Lower
  • IMPELLER KIT, Water Pump
  • B ASE ASSEMBLY, Water Pump
  • BODY ASSEMBLY, Water Pump
  • SHUTTER, Water
  • GROMMET, WATER SHUTTE
  • Found exhaust flapper burned out install new in
    tube.
  • Prior to dropping off for Alt customer stated that the engine
    overheated and had no fluid in reservior tested found defective heat
    exchanger replace with good used one
With that information, i have to receipts for the potential buyers. Plus the pictures below what do you guys think i could get for this stuff??
I Wanna sell
  • engine
  • outdrive
  • trailer
The stuff was painted too, so the outdrive actually looks better than that pic. One last thing in case its not obvious, the boat was used for the season after all this work. Engines runs great, potentials customers will also get to hear it run. What would you guys think for prices? Thanks alot!!
*** Please use attached link to see items talked about here.
