What kind of ATF?
There are a bunch of ATF's out there, all with significantly different qualities and applications.
I NEVER use anything but OEM ATF, I've seen too many transmissions fail due to WRONG fluid.
What kind of ATF?
Here's another ATF tip: use it to lubricate your bicycle chain!
I'm sure it would work until it wore off because it fills in the imperfections that make the plastic lens look foggy. But be careful what you put on those plastic parts because some fluids would simply dissolve plastic parts...brake fluid comes to mind. I use polishing compound (any brand will do) and a buffer on a drill. You would be amazed at the new look you can achieve doing that... That IS exactly what those headlight kits have in them, a polish compound and a buffer pad. Just buy the polish of your liking and use a drill buffer pad...a lot less expensive and accomplishes the same results.
Another: mix with equal part paint thinner to make a good penetrating oil. Using it for headlight lens restore is really amazing.
depends on how you ride but typically that attracts way too much dirt.Here's another ATF tip: use it to lubricate your bicycle chain!
I typically use TriFlow but I am a serious rider.It suits my riding style, surfaces and maintenance schedule. I recently read about it and am trying it to compare to other things I've used.
I use it in my transmission... ;-)
Tri-Flow Superior Lubricant Drip Bottle :: Tri-Flow?Is that stuff graphite based?
