Re: att. OB and Alcan
Hi David<br /> Please keep questions on the same subject on the same post. This will help us help you. That way it allows everybody to follow along. Sometimes the other guys have a better idea on how to do something, or can explain it better.<br /> Now lets figure out whats wrong with your motor. Are you 100% sure that it is gear oil that is leaking? Did you remove the prop? The thrust bushing would have nothing to do leaking oil. Yes by removing the two bolts/cap screws the gear case head can be removed. You will how ever need a manual and some special tools to perform this work. I would not mess with it though, untill your sure you indeed have a gear oil leak. Since there was no water in the gear case, this makes me wonder. I would suggest that you presure test and vacuum test the gear case. These procedures are outlined in the manuals. I you don't want to cough up for a book, see if you can check one out at the library. Believe me these manuals are worth every penney.
