Audible warning switch location
tractoman
On a 1995 4.3LX is the fuel pump safety switch located near the oil pressure sending unit serving double duty to set off the audible sounder in a low pressure situation or is there another switch somewhere? Engine serial 0F588532
alldodge
There are three switch/senders on your motor. The oil sender to show pressure on the gauge, the fuel pump switch to turn pump off if oil pressure is lost, and the warming horn switch that sounds the horn.
