auto carb/marine carb
bolo789
can someone post a pic of what a marine rochester carb look like, and what the auto carb look like, last year when my carb flooded it spill all over the engine, that sounded like a auto carb from this forum discription to me. some say there is a vent on top of the carb thats when it flooded it should go straight down the carb troat instead of all over the engine,<br /><br /><br />please someone post some pic of the diffrence, iam sure it will help me and a lot more. thanks,
whywhyzed
Banned
Re: auto carb/marine carb
search ebay - you should find lotsa shots of any carb you wanna see...
seahorse5
Originally posted by bolo789:<br /> can someone post a pic of what a marine rochester carb look like, and what the auto carb look like, last year when my carb flooded it spill all over the engine, that sounded like a auto carb from this forum discription to me.
You don't say what model carb, but if there are vacuum fittings that are capped off with rubber covers, then you have an automotive carb.
bolo789
seahores you hit it on the head. it does has a that vac that cap off with a rubber cover, man you guy are good. now this is my last ??? i notice on my friend carb his has a little hose that goes to the fuel pump, does all marine/quad carb sopose to have that hose to fuel pump??<br /><br />thanks guys i will be watching the responds
ron7000
Banned
unless i'm missing something i don't believe that capped off vacuum ports mean it's an automotive carb. The carburetor main body casting is no different for a marine version, and most if not all carbs have vacuum access tubes coming off them for various accessories, example = distributor vacuum advance. If you don't have a distr. with vacuum advance, which boats don't, then that particular port on the carb is always capped off. No big deal. I know Holley's are like that. Rochesters have various places they will leak from, and I'm not even sure if all "marine" rochesters have j-tubes to vent the bowl back down the throat of the carb.<br />also, the engine year, make, model along with the carb model and year would be helpful.
Northern Eclipse
It sure appears as if its automotive, but at this point I would scrap that carb and buy a marine carb (rebuilt or new ) If its spilling that much fuel it does not really matter if the current carb is auto or marine its still a major hazard. And yes a marine carb should have J-vent tubes and a clear line from fuel pump to carb base. Check out E-bay under marine carbs for various photos.
rodbolt
I see new PCM marine engines with carbs that have vacum caps all the time.<br /> the carb model may be helpful as rochester has supplied varios versions of 1bbl,2bbl and 4bbl carbs to the marine industry since about the mid 1940's.never saw a quadra-jet with a J tube as the vent is moved aft of the carb throat slightly.<br /> occasionally I will find a reman with a modified tube. the clear hose from the fuel pump goes to the carb passage that is not drilled on the auto version . so while its possible to easily modify the auto version of the q-jet I dont reccomend it. jetting and airvalve and powervalve springs get a bit tricky sometimes.
bolo789
ok so if it does not have the hose going to the fuel pump it is not a marine carb, am i right?? ok guys thanks i think i will bite the bullet and put a spanking new edelbrock 1109 600c. thanks again
Bt Doctur
That hose COMES from the fuel pump and GOES to the carb to carry any fuel from a ruptured diaphram in the fuel pump.if this veny area of the pump was sealed, the diaphran wont pump fuel.
whywhyzed
Banned
sounds like you need a MARINE fuel pump as well if you don't have that hose.<br /><br />Better look at the starter while you're at it... and the distributor.
bolo789
na na the fuel pume is a marine pump. it has the clear hose connect to it but the carb dont have the nipple for that hose to fit on to. i am 100% sure it is marine, my starter is a marine also, mt altanator is marine also, it just this carb junk, so when i got the edelbrock carb do i have to get a new fuel line for that also???. also which choke is best to get on that ect ect
I Might be Wrong,.............Again........<br /><br />But,.....<br />If we're talking about a 4bbl. Carb.......<br /><br />I believe that you're going to need a 1400 series carb......1409, maybe.....
Don S
Just because there is no place on the carb to hook the clear hose from the fuel pump to doesn't make the carb "Non" Marine. Depending on the year, make, model of your engine, some had a connection on the flame arrestor for the hose.<br />Do you have a picture of your carb that you could post? Also, we talking Merc, Volvo, OMC, and what model and year.
bolo789
ok guy it is a 89 merc 5.7 it was not the original carb that came with the boat, i bought it from a guy in the marina who happens to have extra one,<br /><br />now my friend is giving me this other rochester quad carb he stated it is fine,<br /><br />i wrote these numbers of the body, <br /><br />gm 40985<br /><br />17059285<br />0456<br /><br />it dosent has the nipple for the fuel pump rupture line. but as don stated it dosent has to have the nipple for it to be a marine, bondo thanks for the correction on the edelbrock carb. thanks
daveswaves
Ensign
My search for that number shows it is a marine carb, rochester 4mv that was used on a 5 litre chevy/omc sterndrive.
