Auto Glass Anyone?
chicknwing
I have a 94 Ram 1500 with a sliding rear glass. While cleaning the old truck up I noticed the entire glass unit moved with just a little pressure applied. It looks like whatever adhesive was used has dissipated. Anyone have any suggestions on what to use to reseal this thing? I would really hate to loose my glass while riding down the road...:D
TC
ne7800
Re: Auto Glass Anyone?
Well you came to the right place lol there are two ways it might have been installed #1 soft butle with bolts (behind the trim) #2 urathane like the windshild. If it's #1 the nut might have fell off or the stud broke, if it's #2 then you will have to remove the whole window from the truck clean all the old urathane off of the winow frame and reinstal with new urathane.
Bob_VT
I thought the sliding rear windows just used a big rubber gasket w/o sealant. I would check and see if there is a gasket inside that is not wrapped around the frame.
chicknwing
any particular type of urethane? Where is it available? Thanks for the quick reply.
TC
Bob_VT
Huh that is how we used to break into them (legally at a car dealership)....
Go to any glass shop and ask for the urathane to install auto glass. They will usually sell you a tube and to be honest they might even do it for minimal money.
That urathane is some nasty stuff....... word to wise .... wear rubber gloves.
LOL I bet 3m5200 would work but it's bright white!
ne7800
that is the way it used to be but now they are either bolted or glued because widows have become a strucual part uf the cab for roll over protection
ne7800
TC
well I will not call my self a auto glass expert but i have replaced around 40 or 50 window in my life woking in body shops and i use ....................... ready for this .....................what ever CarQuest gives me when i call them and tell them i need some LMAO just as long as it is ment for auto glas it should work
windsors03cobra
I've replaced a few late model rear windows and use a 2x4 in the front window frame and a 2x4 across the back window along with some pony clamps, ratchet straps or whatever to hold them in place after setting the window in
yhst-94715171101240_2048_5200820
Available at any auto paint supply or decent auto parts store, about $15. Be liberal in the application.
chicknwing
The frame is all one unit, no bolts, no gasket, appears to be glued in, as many times as I go to advance in a week I have never sen any kind of window glue...other than the rear view mirror glue, guess I will check NAPA. Thanks for the advice and the direction to go....
TC
chicknwing
thanks windsor...that answers all questions....
TC
ne7800
That is what CarQuest gives me right there lol
chicknwing
Certainly appreciative for the great pic with the part number;)
TC
windsors03cobra
No problemo I really hate hot linking stuff like that but te picture was the right size and clear so I hot linked anyway.
