auto or trailer tires?
freeskimon
I know I should probaly go with trailer tires to replace my 215 70 14 tires - but I'm curious to what you guys think the big difference is?
Bob_VT
Re: auto or trailer tires?
Weight bearing capability. Trailer tires have better sidewalls for the load and can take the extra heat too. I wouldn't try to save a few bucks at the risk of my boat.<br /><br />Bob
sangerwaker
Your tow vehicle mileage will decrease with car tires on your trailer. Trust me...I know this from experience. It's worth the extra $$ for both safety and mileage.
rwidman
This from the Champion Trailer website:<br />
Trailer Tire requirements differ greatly from automotive tires. Automotive tires must maintain traction during all driving conditions: pulling, stopping, turning, or swerving. Because of this they must have more flexible sidewalls to maintain tread to road contact. Since trailers have no driving torque applied to their axles, the only time trailer tires must have traction is during the application of trailer brakes. <br /><br />Trailers with heavy loads, high vertical sideloads (like camper trailers), or trailers with inadequate tongue weight can be affected by trailer sway problems. Automotive bias or radial tires with their more flexible sidewalls can accentuate trailer sway problems, whereas the stiffer sidewalls of the ST (special trailer) bias ply tires help to control and reduce sway problems. For this reason it is not recommended that (P) Passenger or (LT) Light Truck tires be used on trailers. Best trailer control will be achieved with (ST) Special Trailer tires.<br />
Read the entire article here:<br /><br /> http://www.championtrailers.com/tire_art.html
jlinder
Here is another reason to stay with the tires the trailer is rated/designed for - insurance.<br /><br />What if you have an accident? Will insurance balk because you don't have the spec'd tires?<br /><br />I don't know, but I do know I don't want to find out.
agrazela
When I bought my rig used, the trailer had automotive tires. After I replaced with trailer tires, there was noticeably less sway and bounce...and my rig weighs less than 2000 lbs fully loaded.
jlinder
Originally posted by NYMINUTE:<br /> BOATING: Your Super Highway to BANKRUPTCY.<br />
On ramps everywhere. Off ramps limited
freeskimon
Thanks for all your input. After reading your feedback and doind a little research, I eneded up ordering two new tralier tire.
