automatic bilge pump switch
Wreck Rider
Hey guys (and girls), I'm looking for help finding a float switch (or something that does the same job) that simply will not break.<br /><br />I run mine manual because the boat is trailered but my Dad and a bunch of his friends seem to have the same experience - the darn things always break, either the wires come apart at the float or they simply stop working.<br /><br />Whatever the reason they don't last. The mercury ones are pretty expensive where Dad lives (Honduras) and I was hoping to take him down a good one next visit if I can find one. Ideas?....
18rabbit
Re: automatic bilge pump switch
I really like the SensaSwitch from MSC corp. No moving parts, fully enclosed.<br /><br /> http://www.msc-emd.com/sensaswitch.shtml <br /><br />May not work for all boats; turns on when the water is 2-in deep and off when the water pumps down to 3/4-in. So if 1 1/2-in of water in the bilge will ruin your day, the SensaSwitch isn't for you.
Wreck Rider
Thanks, looks like that would be just right!
cbcrawford
Personaly I like the pumps with the built in Float switch, the "contained" nature of them makes them less prone to damage, and since you are installing them as a unit there is less chance of acidental damage by the user/installer.<br /><br />But on the same note, make sure that it's one that actualy has a FLOAT, not that 'tests' periodicaly for a load, the 'testers' will wear your batteries out when you least expect it.<br /><br />Best of luck!!<br />CC
