Hello all!
I’m wiring my bilge with a float for backup. I want a on-off dash switch where I can turn on to manually activate bilge and when the switch is off, the bilge is controlled by the float. I’m planning on using a 5 pin relay for this where terminal 87 will go to bilge pump and 87a will go to float switch then to pump. When you turn on the dash switch, relay (will close and manually activate bilge. When I turn off switch 87a will close and the float becomes the “switch”. I attached a diagram. Will this work? I’m 99.9% sure it will, but I want to get a second look.
thanks!
thanks!
