My rig: 2002 Monark King 170
2003 Merc 90HP 13x19 prop
35MPH (GPS)
5200 RPM
I've seen dozens of posts suggesting the AV plate needs to be at or 1-2 inches of the transom.
When looking at my motor, there are 2 plates. The AV plate just above the prop which goes completely around the shaft. 2-3 inches above that, there's another plate which only goes around the front half of the shaft.
What's that higher plate called?
When my motor is trimmed all the way down, it's the upper of the two plates thats even with the keel of the boat.
Is the motor mounted too low? It came from the dealer this way, so one would think that the motor is mounted correctly.
Thanks...
35MPH (GPS)
5200 RPM
Thanks...
