Ok so I've read through a couple post here on the height of the av plate and tilt on trying to get my boat to plane. My boat is an aluminum, 14ft sea nymph, regular v hull, with a 15404s evinrude 15 hp motor. I'm usually the heaviest person in the boat in the back. My boys go fishing with me too but hull still comes out of the water a little. With just me in it the hull comes right up and out of the water. Right now my av plate on the motor is 2 inches lower than the bottom of the transom. But my boat also has a runner on the bottom of my boat. The tilt on my boat is straight up and down. Not turned out away from the boat and not turned in towards the boat. Should I raise the motor to make the av plate level with bottom of transom? Would that help get it somewhat to plane out? Other guys I see on the lake by themselves in boats like mine they are flying across lake and their boats are plane out. I was planing on raising the engine mount 2 inches to help bring the av plate up level. I can take pictures if needed also. Thanks in advance
