Avatars
NYMINUTE
I have a pic on freepichosting.com can't get it loaded here to anything beyond the red X. How do I do this??
url]
:confused:
sangerwaker
Re: Avatars
I also use that site. Get the "image source" url for the picture. Copy and paste that address.<br /><br />It should look like this: (this is one of mine)<br /><br /><IMG SRC="http://www2.freepichosting.com/Images/421564122/0.jpg" BORDER=0><br /><br />The info you want is between the quotes. Paste that info into the image box here on the iboats site.<br /><br />You can also mess around with the size by looking at the "details" on freepichosting. There will be an "x=..." suffix. That will change the pic size.<br /><br />
sangerwaker
Re: Avatars
Are you signed in on that site? I can't make it work yet either.<br /><br />You must have signed in cuz it's obviously working now!
NYMINUTE
Re: Avatars
I was, still get an X, Do I paste the www. in the set URL box on change Avatar?
sangerwaker
Re: Avatars
I always C&P what's inbetween the quotes, and when I hit the IMG button, I delete the www there. It's already in what you copied from freepichosting.<br /><br />BTW-that pic is too big for an avatar. You need to reduce the size.
sangerwaker
Re: Avatars
Try this one.<br /><br />
<br /><br />Save the pic on your PC, then upload to freepichosting.<br /><br />BTW-nice looking pooch!
SpinnerBait_Nut
Re: Avatars
Yea me too, just seems they are having some problems this am, maybe server overload.
sangerwaker
Re: Avatars
I hope not. Didn't they just upgrade?<br /><br />Proly overloaded from us! :eek:
SpinnerBait_Nut
Re: Avatars
All you have to do is when you have the picture uploaded and updated, just click on get info under the picture and it will copy the url to your clipboard and then all you have to do is paste it where you want it.
NYMINUTE
Re: Avatars
Still can't get the Dane to load as my avatar. I pasted the url in the Set URL box where all the avatars are. Red X This can't be that hard. What am doing wrong? I made it smaller.
sangerwaker
Re: Avatars
After "set url" does your picture show up in the upper left corner of the screen? You must then hit the "select this avatar" button.
sangerwaker
Re: Avatars
Try this. This is from my files, but you can use it until you can figure yours out. It is your picture, though.<br /><br />Copy this (completely)<br /><br /> http://www2.freepichosting.com/Images/421570826/0.jpg <br /><br />Paste this into the url for avatar box after deleting anything that is in the box. Set the url and select avatar.<br /><br />BTW-your address should look EXACTLY like what I said to copy above, only the numbers should be different.
ebbtide176
Re: Avatars
ok, i finally broke down and did the avatar thing :) if i shrink it anymore, it will be even harder to figure out... but feel free to guess :D
