B. Tilland
- Oct 2, 2010
- 4
I have an old Avon Redcrest that my dad carried on his sailboat. He was mainly a live aboard and I don't remember him ever using it. It's been in its carry bag for years. It holds air and appears to be in excellent shape.
The only part of it that's beat up are the plywood floorboards. I'm going to sand them down and put some marine varnish or polyurethane on them -- I may have to replace the middle one but the two end ones are certainly salvageable.
One of the three pieces still has a "rib" down the middle -- a beveled piece of wood about 2" high and 1 1/2" long. The other two plywood pieces have holes for a similar rib and an outline on the surface which indicates that ribs were once attached to them as well.
I'm assuming that the rib side is down, because having a rib on top wouldn't serve any purpose. There is certainly nothing structural involved. Also. the bold heads on the top of the rib are recessed while the bolt ends and nuts are not -- and you certainly wouldn't want the bolt end and nut sticking into the rubber bottom of the boat.
What is the purpose of these ribs? Do they have any function as a kind of rudimentary keel? Or are they just there provide a little space under the floorboard for water so that the top of the deck keeps a little drier?
