I recently got a 1968 40 hp Johnson Electromatic RKL( 30C) that has been in a garage for about 4 years or so. Was told that it ran great prior to taking it off his fishing boat as an axillary motor and replacing it with a 15 hp kicker. I have a service manual that should be delivered by tomorrow from Ken Cook. I read the FAQ on Awakening a Sleeping Outboard. I got a carb rebuild kit, seals for the vent and drain screws, impeller and housing (just in case). My questions;
1. I can remove and clean the fuel pump but necessarily I neccessarily need to replace it? How can I tell if the fuel pump is bad?
2. Is there anything special I should be aware of Electromatic regards to the "Electromatic" shifting and getting it back up and running or installing the impeller?
3. From other posts, this motor should use Type C gear lube. I see at the dealer that they have a Johnson Hi Vis gear lube. Is there any advantage to using one over the other.
4. Anything else that i should watch out for.
Thanks,
Kevin
Thanks,
Kevin
