Re: B.P. filter/separator
It all depends on your boat/motor/fuel tank size, etc. I run a 90HP motor with a 12 gallon red plastic "portable' fuel tank, which I can dump and clean as needed, so I have very little, if any, water or trash in my fuel system, so my Walmart($27) fuel/water separater is more than sufficient for my rig. If you have a large, built-in fuel tank that you can't easily drain and clean, then a more sophisticated filter(Yamaha or Racor) would be much better. If you have much condensation/water/debris in your tank/fuel system, then the units with the clear, drainable bowls would be great. Get the unit that fits your needs, but be sure and get one! Good Luck!
