b2 engine mounting ???
Hello all im new here and new to restoring boats this is my first, My question is i have a 1974 glasspar 165 cutlas with a volvo penta b20 engine and a 270 outdrive, im pulling the deck out and found i need to pull the engine. right now the only way the engine is being held in place is by the transome, there are no motor mounts securing the engine the the hull in anyway, is this correct?? or do you all think there should be mounts on the stringers? please help.
wellcraft19
Re: b2 engine mounting ???
There were some early model Volvo Pentas that had the engine "cantilevered" off the transom shield. You likely have one of those.
yeah i did some more looking and i cant see any signs that there were any kind of mounts. thanks for the info im going to keep it the way it was after i beef up the tramsom a little
PiratePast40
Don't forget the mount that attaches to the bottom of the transom shield. The engines bounces up and down on that so it's just as important as the rubber donuts and locking collars.
