rickasbury
Master Chief Petty Officer
- Jul 13, 2011
- 800
So, just getting my 06 350 mpi back in the water after 2 years of a transom asy rebuild-/repair. So first attempt I had a bad trim actuator and power steering leaked all the fluid and burned up the pump. Do, after those repairs back to the water today. Getting the boat going, I pretty much had to peg it to get it to plane out and it was slightly surging and not quite opening up- and really started back firing. Do after I ran it a bit, it would plane out easier at less throttle and was not backfiring. Admriial was to call sea tow and had an estingusier in each hand so did not open it up again. I put fresh gas in . Boat has 300 hours, plugs 200. Arestor I don't think has ever been cleaned. Plug wires are probably original....just need to run it some more? Don't like that,!
