1960 Johnson 40 hp, rds-22 engine. Have changed plugs, plug wires, coils, condensers and points. Rebuilt carb and changed lines. Finally got through a overheat prob (separate post), running a test again and trying to trying to adjust idle.
Found out by pulling plug caps to test spark that I'm only running on top cylinder. I suspect this has been one of my probs all along now. I thought possible problems might be a plug wire not seated in the coil right and shorting out. Might also be the vacuum kill switch malfunctioning.
Any other thoughts?
Any other thoughts?
