trumanlake
- Aug 8, 2003
- 131
I have 1985 merc 200hp ser# 6625329. Have had the same problems everyone else has had. Intermittent beeping hit it, it quits. Replaced module, idled past no wake bouys gave it the gas, about an 1/8 mile later, here we go again, beep,beep,beep.... I understand it compares the signal from the 3 wire hall switch to the outboard switch box(#4 cyl). My question is, can the comparison be made to say #6, or is this strictly a timing signal that can only be in sync with #4?? This would eliminate purchasing a switch box, right? If the problem persists. (2) Second question is everyone talks about plugging the shaft hole and the lines, but what about the warning module? You still want overheat warning! Do you simply disconnect the switch box signal? I purchased a Clymer manual, doesn't really cover wiring for this motor exactly.
