swampfx914
- Jul 22, 2003
- 14
Ok guys here it is... I have a 1994 Sea Ray 250 EC with the 5.7 mercruiser. There are less than 300 hrs on the motor. The boat sat unused for a year. When I got back to it there was water in the cylinders and in the carb. I drained the cylinders I ran ATF fluid throught the intake until it was coming out of the cylinders until it was all out of the cylinders. I rebuilt the carb. I have run the boat several times with no problems. I was at the lake and decided the gimble bearing was making to much noise for me so I changed it. The next time out the boat started back firing through the carb. I pressure washed the engine making sure to stay below the carb and away from the distributor. I have changed the wires,plugs,dist cap, rotor and coil. (thunderbolt IV HEI) I have put another carb on it for testing purposes and have the same problem. I have removed the valve covers and looked for bent push rods, broken springs, etc. When I accelerate from idle fast, the engine "loads up" and will not run I can accelerate slowly and it will rev fine. once I get above about 1500-2000 rpm I can rev up and down with no problems. I have checked and rechecked wire routing. I have not checked the timing yet but i plan to tomorrow. This engine has not been run that much so I don't see how timing could be an issue yet. please let me know what you think. I have read every post on here reguarding backfiring and none seem to quite fit my problem. I will thank everyone in advance. I appreciate the help. Brandon
