nextboat1
- Mar 17, 2013
- 82
Hello,
I recently purchased a new to me boat and am having some issues. The boat is a 1998 Rinker Captiva 232 BR with a Mercruiser 5.7, Alpha drive, and Thunderbolt 5 ignition. The engine serial number is 0l020702. All testing has been done while running on the muffs in the driveway. After a couple pumps of the throttle, the boat will fire right up and run at about 1000 rpm. It seems a bit rough, but smooths out a bit once warm and will then idle correctly at 650 rpm. However, when I try to rev the engine rapidly it will backfire through the carb and then increase rpms as intended. If I slowly increase rpms it will not backfire. I'm not sure where to begin my process as far as diagnosing the problem is concerned. Does this sound like more of an ignition problem or carb? I cannot say for sure, but the cap and plug wires look to have been changed recently. I also noticed that the tach occasionally goes "whacky" and will give a false reading. Eventually it will return to the correct rpm. Could this maybe have something to do with the problem? Thus far, I have verified that the accelerator pump is in fact squirting fuel, all plug wires are secure on both the cap and plugs, and the engine temp gauge was verified to be reading correctly at 160 once warm with an IR thermometer. Any help will be greatly appreciated. Thanks
