Gents,<br /><br />I recently bought a 1990 Wellcraft St. Tropez 3300 with twin 7.4L Mercruiser inboards, supposedly recently rebuilt. The starboard engine runs great but the port engine makes a constant popping sound through the carburetor and sometimes through the exhaust while cruising above 3500 rpm. It does not do it as often at lower rpm’s. <br /><br />I had the carburetor rebuilt and it improved a little bit, especially at idle and low rpm. Ignition system looks OK. I can not tell much about the sparkplug wires. Would a simple continuity check be enough to tell if they are good?. What resistance should I expect? <br /><br />One more thing, apparently when the engine was rebuilt, they found that one of the heads cracked. So they were replaced with a newer generation heads. I’m not sure if they changed the valves and valve springs. On of the possibilities is that they did not and the “weak” springs do not close the valves entirely thus causing the backfire. <br /><br />I need guidance as to what to do next.
