Backfiring after starting HELP
RyanM3
Finally got my boat cranked! Feels great to accomplish after 3 weeks of frustration. However, it now backfires when i start it. It will stay on longer if I close the valve at the top of the carb. The boat has been sitting for 4 years. If I dont close the valve, the carb catches on fire after backfiring. Also, alot of smoke comes out before backfiring. What should I do?
1987 Glasstream 172 cutlass
3.0L 4cyl mercruiser i/o
dubs283
Re: Backfiring after starting HELP
sounds like the timing is off, have you checked it??
RyanM3
no I have not. How do I go about doing that?
dubs283
timing light connected to #1 plug wire
RyanM3
i dont have a timing light. Is there anything else I need to check?
CobiaXL
Banned
Firing order correct?Spark wires on correct?Points corroded?Fuel level to high,check to see if raw fuel is dumping in carb at idle.Watch your face if it backfires.1-3-4-2 clockwise on dizzy cap is your firing order.
RyanM3
Firing order is correct. Spark Wires on correct. Just changed the points.
rickryder
You can find the proper procedure in your service manual on setting the timing....
