brandon6.0
- May 19, 2012
- 47
My new boat is a 92 Astro 17.5ft with a 92 Mercury 150 XR6 carb. Here is the problem:
Took boat out last 3 weekends since purchase and noticed at WOT hole shot at 3k rpm it would just hit rev limit or cavitate very badly. Had to back off throttle to easily get it tp plane out. Once riding i was only seeing 5000 rpm trimming up a pretty good bit. Now i know i should be seeing 5-5500 on this outboard.
Could prop be an issue? Prop has a few signs of wear but no dints or dings. Currently has LaserII 24p. Thought about running a 23p Trophy plus. For a lil more bow lift.
Checked motor height on transom:
-Bottom most part of hull or keel (15")
-anticavitation plate (18.5")
-Prop center (10 1/4")
-transom to prop center hieght is (4 3/4")
Motor is currently in the highest setting on transom. Looks to be from factory hince no marks from bolts on other holes. My transom has a cut in at the back from the transom of about 12".
Lookin forward to yalls thoughts. Thanks guys!
