I was out one night last week, cruising along at about 3500-4000 RPM (1989 Johnson 120 TL). All of a sudden, WHAM, it felt like I hit a log or something submerged (middle of the channel, 15 ft depth, no charted obstructions). The whole boat shuddered. I immediately throttled back. It was dark, I did use my spotlight but did not locate anything floating after a few moments search. I was more concerned to head back home rather than continue the search in the dark.
First thought through my mind is the clutch dog. After arriving home, I went through the service manual to see what kind of job it would be to change it myself. This is definitely within my capability and would consider to do so myself, though I would also price out what a local Evinrude dealer would do for the job.
I've since taken the boat out several times and nearly 100 miles without an incident. Initially just a bit to confirm, then I took a long ride down much of the length of the CT river just south of Hartford to the Long Island Sound (40 sm each way). Part throttle, WOT, no problems.
Thought I still consider a worn clutch dog as the leading cause, I'm wondering if I might really have hit a log, or submerged object.
Is it possible to have an "isolated" occurrence of clutch dog failure, which does not repeat. Or if it was indeed due to the clutch dog, is it certain to occur again (and increasing frequency)?
Now something I shrink to admit but must because of it's relevancy: at the beginning of the season I changed the water pump. I was careful (or so I thought...) not to disrupt the orientation of the shift rod (e.g., shift-rod height). However, upon installation, I had difficulty installing the shift rod pin. I could only align the pin if I engaged very slightly into gear. I did have to adjust cable to make reliable, clean shifting into and out of neutral to fwd and reverse. I had figured no damage, since I compensated the length of shift-rod offset by the amount of cable adjustment (I might be slightly off, because the travel is an arc, not a straight line). Is it not reasonable to compensate for shift rod mal-adjustment through adjustment of the cable length? Or is this a likely culprit.
thanks,
Paul
thanks,
Paul
