Bad Day
SpinnerBait_Nut
Well what started out to be a good day turned into a bad day. :( <br /> <br />Was on the way to the lake and as I got off the interstate, noticed I could see a lot more of the inside of the boat than normal. :confused: <br /> <br />My first thought was that the bow stop had broke or moved down and let the nose of the boat down, but nooooooooooo!!! :rolleyes: <br /> <br />The trailer had broke behind the crank down dolly to the point that the wheel on the dolly was on the ground. :mad: <br /> <br />I guess that's the only thing that saved it from breaking plum into.<br />Man what a site that would have been, fiberglass bass boat pieces flying all over I-64. :eek: EWWWWWWW!<br /><br />Well I got it into a gas station and got a buddy of mine to come out and we drilled a hole down through it after raising it back up to where it was suppose to be and put a case hardened bolt in it so I could limp it to a place with a welder to get it fixed back up.<br /><br />The good part was it just cost me $35 to get it fixed :cool: and it could have been a lot worse if the nose of that trailer had got to the blacktop at 65MPH. :eek:
bubbakat
Re: Bad Day
someone up above was looking out for you and I don't beleive it rides around in a space ship either<br /><br />Sure glad you were watching the mirrows to :cool: :cool:
snapperbait
Re: Bad Day
WOAH! I'd consider myself luckey if'n I were you.. Catastrophe avoided.. :eek: <br /><br />Might be a good day to buy a lotto ticket? :D
OBJ
Re: Bad Day
Good to hear ya' came thru unscathed. $35 is a cheap bad day when talking about "losing trailers or boats" from the tow vehicle.<br /><br />Keep on truckin' buddy! :D :D
KennyKenCan
Re: Bad Day
After hearing about this, it makes me appreciate the cost of my boat slip more.<br /><br />Glad to hear that you came out unscathed!<br /><br />Kenny
D
DJ
Guest
Re: Bad Day
Uffda, close call-eh!!!<br /><br />Glad to hear, all worked out.
JGREGORY
Re: Bad Day
Somebody was watching over SBN. And it wasn't aliens because if it was they would have use their tractor beam to keep it from breaking in the first place. :D
gonfishn
Re: Bad Day
Glad you came out OK...If it had to happen....better now then when you were heading to the get together..
mellowyellow
Re: Bad Day
whoa! :eek: <br />close call SBN! part luck and part smarts on yur<br />part. just think if'n u wasn't watchin....<br />good lesson for all!
LadyFish
Re: Bad Day
Phew, it could have been so much worse. Glad it turned out like it did for you. :eek:
FLATHEAD
Re: Bad Day
You are one lucky SOB spinner. Good thing you were paying attention to what was going on back there.
GodsBeast
Re: Bad Day
Glad you and your boat are OK, you are confident in the welding job, right? Way to keep an eye on things ;) <br /><br />GodsBeast
Scoop
Re: Bad Day
SBN, I am glad you and everyone else is ok and it was a cheap fix. I bet that adrenaline was flowing when you saw it.
