My main reason for this post was to determine how water was getting into my oil. The reason i thought it may be a flapper valve is first symptom i noticed was trying to restart engine after stopping and determined water was getting into the cylinders on one side, checked the flapper and it was bad on that side so i replaced them...great, easy fix...not. Ok checked the riser gaskets, (per advice given here) the one one the side with water was bad and standing water in manifold. OK...thats how water is getting into the cylinders but i am still not convinced that is how water is getting into the oil as well, oil is totally white.(Convince me it is please).
After taking off both risers and manifolds i did a compression test Not very accurate as it was not up to temp but got 110 to 130 lb readings. Did a pressure test on the cooling system. Blocked it all off put in 15lbs pressure. Now this is the first time i have done this so i am no expert...It takes about 5 minutes for the pressure to leak out, sprayed soap water around my fittings to see if they where leaking, they seem fine. I can here a faint air leak but it seems to be coming from the water pump, mayby the seal? Is that possible? Would a cracked block be more obvious? Just trying to be 100% sure there is a leak in the block before replacing the engine.
