Bad Fuel pump ?? 150 black max
I posted a week ago , did not get any response except some one might have peed in my gas tank. .. Boat would Idle barely and once I hit forward gear it could be Kept running with the "choke".
Does this sound like a fuel pump issue ? compression even on all 6 .
Spark on all six.
Boat ran for a mile and a half on its first run of the season .
hkeiner
Re: Bad Fuel pump ?? 150 black max
It could be many things. To test for a fuel delivery problem, you can try squeezing the fuel bulb while the motor is idling and see if that helps. If it does, you have a fuel delivery problem, which could be a bad fuel pump, fuel line restriction, dirty carbs, etc. To narrow the problem down further, you can hook up a vacuum gauge to the fuel line to test things further. The below links provide some guidance on this.
I find that it is usually better to do some systematic troubleshooting to find a problem that to repair/replace a lot of things on a hunch until you hit on the culprit. Of course, cleaning the carbs is never a bad idea if it has not been done in a few years, to eliminate that as a possible problem
http://forums.iboats.com/attachment.php?attachmentid=26607&d=1240244928
http://forums.iboats.com/attachment.php?attachmentid=26608&d=1240244937
http://forums.iboats.com/attachment.php?attachmentid=26609&d=1240244945
http://forums.iboats.com/attachment.php?attachmentid=26610&d=1240245079
