Bad gas mileage
rainman99
I have a 1985 Johnson 90 Hp. Got it at the begining of June , have had it out 5 times now first 2 times I was getting 2 miles a gal. of fuel. The past 3 times im only getting 1 mile a gal. average speeds 25-30 mph mild curent and chop on the Ohio River ,useing Quick Silver med grade gas at a 50-1 mix. Motor on muffs little smoke fuel smells a litte rich , plugs have a little carbon build up have 125 psi compression runs and idels great on and off the water. What now adjust jets and timeing? Thanks for any help you can give.
Rainman
kenmyfam
Re: Bad gas mileage
Before you rip anything apart, gauge your fuel usage in gallons per hour. Miles per gallon is not a good way to measure fuel consumption on a boat in my opinion.
Your 90hp should use around 9 gallons per hour at WOT and at a comfortable cruise significantly less.
tashasdaddy
