bad head
natural
i have a 1988 125hp force replaced head gasket.and water is spraying out of the top of head and low right side.pulled head back off.and checked the head it is pitted how can i fix? :eek:
Johnshan1
Re: bad head
If the head is pitted that means metal or something else was bouncing off the piston and head, how do your piston tops look?<br />-John
natural
Re: bad head
a freind of mine pulled the head off.but it wounld not move so he used a screw driver
jim phillips
Re: bad head
Every one needs a friend like that... If it not to bad you might try fine sand paper on a block of wood to smooth it out
natural
Re: bad head
its bad will silcone work?if not i will have to have it welded up and recut to make it true again :(
