bad kill swich make engine bog ??
lobster1203
i have a 1986 etxj yamaha 200 had a bad bogging down problem when given any rpm it didnt have any spark. so i took stator and trigger off cleaned and lubed put every thing back together i also took off the two white wires that come off that black box for the kill switch whitch i learned on the forum . started and it ran great no bogging thinking it was stator or trigger that was the problem wrong!!!! flooded it to shut it off , put white wires back on so i can shut it off with key started it back up same bad bogging prob took wires off ran great can a kill switch kinda go bad or do i have some sort of bad ground somewhere i didnt change kill yet great forum thanks for any help
matt2002
Re: bad kill swich make engine bog ??
It could be the kill switch.Check it with a meter to make sure its not shorting out somehow.
