Bad Plugs????
Joe Reeves
Re: Bad Plugs????
What engine do you have (model number), and just exactly what is the engine doing?
To answer your question, of course bad spark plugs will affect any engine's performance.
Absolutbost
Re: Bad Plugs????
I have a 1980 johnson 9.9, and it seems to not run wide open, full throttle will only get me 10 mph in a 14 aluminum duracraft jon boat, even with a new prop. Thanks for you help.
Absolutbost
Re: Bad Plugs????
Joe, also its a sailmaster that was converted to short shaft, it has a different prop though, not the sailmaster prop. and its an electric start. thanks
F_R
Re: Bad Plugs????
Sure a bad plug will cause it. First check to see if you have a minumum of 3/8" spark on both wires. If you do, try a set of new plugs.
Silvertip
Re: Bad Plugs????
If you have no spark or weak spark, you need to buy a service manual and begin troubleshooting the ignitiion system. If buying the manual is out of the question, visit your local library. They often have manuals.
Joe Reeves
Re: Bad Plugs????
(Compression & Spark Test)
(J. Reeves)
1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi (somewhat less on the smaller hp engines) and even on all cylinders.
2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On the solid state OMC ignition systems (yours) from 1973 to the present, set the gap to 7/16". The spark should jump the gap with a strong blue lightning like flame..... a real strong blue snap!
If the above checks out as it should, and the engine dies out when throttle is applied or won't idle, it is usually due to the carburetor being fouled, in which case the cure would be to remove, clean, and rebuild it.
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Note: Spark plugs should be Champion QL77JC4 plugs, gapped at .040 .
