Re: Bad Pulley
Rusty pulleys eat belts fast, so either cleaning or replacing will stop the belts from going bad so fast. The trick is, they have to be painted with a good heavyduty paint that has dried in order to keep them that way.<br />I clean them with a 4" disc sander with a fine grit disc. I stick a bolt in a vise and put the pulley on it so it will spin with the disc sander. (it prevents flat spots) then just sand till smooth. Then primer and paint with several coats of paint with something like Rustolem and allow to dry for a week. If it isn't allowed to dry enough, the paint will go away in a hurry.<br />Each fall after the engine is winterized, remove the belts and clean or touch up the paint as necessary and you will be ready for next year after you put the belts on.
