JENNIE116LOWE
- Mar 31, 2013
- 86
Well, I thought everything was going too smooth. Trying to revive a 56 Evinrude bigtwin 30 and I did all the basic tune up things like replacing coils, points and condenser. I rebuilt the carb and replaced the fuel lines, replaced impeller, put in new gear oil and rebuilt the wiring harness converting it to a 12 volt system. I filled my barrel with water and hit the choke and starter button and nothing happened. I retraced all wiring on the 12 volt conversion diagram and everything is as it should be. I ran wires directly to the starter and it would click but not spin so I know my starter is bad? Is the replacement part for a 12 volt starter 277432? Any way of checking my wiring so I can be sure I did it correctly? Can I check to see if my starter solenoid is good? Any help is appreciated. Thanks
