Re: bad stator=battery charging probs?????
Yes but the most common problem is dirt or corroded connections. Check them all to be sure they are clean and tight. Next most common is you rectifier/regulator. If you have ever connected the battery up backwards, even for a split second, the rectifier is toast. They can be checked according to your manual.
