Bad stator?
jsaylor
1987 150 mariner serial 0b117357 I'm going to order a stator, under 900 RPM runs on 3 cylinders, runs good beyond, I've not done a voltage check however I have done an ohm check, all disconnected from the switch box, my blue/white reads 125,000 ohm's. My question is why does it run good over 1000 RPM?. Spark check shows bad on one bank, 3 cyl. People have mentioned they could be a 16 amp stator or a 40 amp, however the sale people say as per serial number it could only be a 16, I was just thinking I'd like to order prior to removing.
Thanks
wired247
There are two sets of coils on your stator. Theres a high speed coil and a low speed coil for each switch box. If you arent getting spark at low RPM...Tada...Low speed coil. You have a 16 amp system.
The Mercury number for the 16 amp stator is 398-5454A35. They run about $175
jsaylor
Thanks, do you know if the blue/white is low speed or high? this is the one that should be about 5k ohm's
enginepower
Well since it's not working at low speed and resistance is off the chart, I would say that it's the low. And yes, spec for that is 5000-7000 ohms.
