Guy's,
I've got a 1987 115 hp Inline 6.....
I recently replaced a faulty upper switchbox (lost ground b/c of loose mounting bolt). I replaced the old switchbox with a new OEM from Mercury. While the motor now has good spark to all 6 cylinders, it will not run higher than 4600 RPM. It previously ran 6,000 RPM WOT.
I put a timing light on the wires and found that the spark pattern on ALL cylinders at WOT is a little erratic. Whereas at idle the timing light binks nice and constant at idle speed, at WOT it does not have a perfectly consistent blink. I'm not sure if this is just a limitation of my $40 Autozone Timing Light or if this is truely an indication of a high speed spark problem.
I'm thinking that my old lower switchbox was also partially damaged by failure of the upper unit and is now causing problems in the bias circuit of both units. Should I just buy a matched set of CDI switchboxes and keep the "newer" merc unit as a spare?
Everything else has been done: New bulb, rebuilt carbs, rebuild fuel pump, new spark plugs, link and sync,etc. Boat now idles and starts great
Does everyone agree erratic high speed spark pattern on all cylinders is the fault of the remaining original switchbox?
