Hey guys,1972 125hp johnson. The timing started to act funny at the beginning of this season when I changed my oil and did a few other things to prep for boating. I had replaced the fuel lines and pump because they had never been done. The motor still skipped but the engine always ran at a good temp. I put a carb kit on the carbs and very slightly I mean very slightly adjusted one of the timing screws. Right after you could play the piano to this thing it was so consitantly beautiful, but then it started to get hot. Water was still coming out of all the usual spots, but after a minute or so the engine became quite hot, but there was water coming out of the tell tale's. I shut it down for the evening, then fired it the next day. Water was pumping good on the hose and engine off but as soon as I start the engine the water stops flowing out of the holes.
QUESTION 1- Could bad timing have killed my impeller?
QUESTION 2- Should I replace just the impeller or the whole water pump kit?
QUESTION 3- Is there a way to test my thermostat as well, and should I replace that as well?
That's all my rediulous questions for now, any comments will help. I have all the literature I need to do the job and am quite capable of doing so.
